KW82 protocol initialized.
ECU ID= NT,90492433,2514a,03A06a,02,
Measuring blocks information:
Battery Voltage,13.6 V
Fuel Pump Relay,Active 0V
Engine Speed,736 RPM
TPS Signal (Throttle Position Sensor),0.45 V
Mass Air Flow Sensor,9 kg/h
Coolant Temperature,1.29 V
Coolant Temperature,83 °C
Intake Air Temperature,1.72 V
Intake Air Temperature,34 °C
Cyl.1 Knock Retard,0 °CA
Cyl.2 Knock Retard,0 °CA
Cyl.3 Knock Retard,0 °CA
Cyl.4 Knock Retard,0 °CA
Secondary Air Pump Relay,Inactive 12V
EGR Pulse Ratio (Exhaust Gas Recirculation),0 %
Fuel Tank Ventilation Valve,0 %
O2 Sensor,117 mV
O2 Sensor Loop,Open
O2 Integrator,139 Steps
O2-Loop BLM Idle (Block Learn Map),133
O2-Loop BLM Partial Load (Block Learn Map),176
Desired Engine Idle Speed,704 RPM
Idle Air Control,123 Steps
IAC Integrator (Idle Air Control),27 Steps
IAC Adaptation Slope (Idle Air Control),132 Steps
Torque Control,Inactive
Telltale (Check Light),Off 12V
Spark Angle before TDC (Top Dead Centre),3 °CA
Engine Speed Limit,Inactive
Injection Pulse,1.7 ms
Blink Code Request,Inactive 12V
Изменено: Antif, 27 Март 2012 - 18:11
